Minor Suggestions in System Booster Section
MCD IT
Post by MCD IT »
Just two very minor and pernickity suggestions:
1.) It would be very handy if the "Empty Temp Folders" button gave a pop up to say how much space was gained.
2.) The "Pc Health" indicator on the error scan might be only a little bit sensitive. This is very minor, but I say this because at least once I had been on a callout where the customer had wanted to see what I was doing out of curiosity, and I have had to explain to them after a scan that the "PC Health: Average" or "PC Health: Bad" is a little too sensitive and doesn't necessarily mean that the computer is in bad shape any more. (This happens, of course, only because the system was particularly bogged up and had a number of files that could not be deleted.)
Not major, just detail work!
I post these only because you seem to be cracking on with the updates so well and might be appreciative of the feedback, but otherwise, I have to say, really nice work with the latest version of the beta. You are on fire! Even as far as to make the settings file-drag over better. Now the batch file you made for me in the previous thread is perfect.
Re: Minor Suggestions in System Booster Section
Hi MDC IT.
I scheduled both your requests for the next update.
Thanks for helping make UVK better.
MCD IT
Post by MCD IT »
Excellent, thank you.
