Kill and rename
Kill and rename
I would love to see a kill and rename option for processes. The kill and delete worked incredibly well on a major spyware infected PC, but it would be nice to not delete in case you click the wrong one.
Re: Kill and rename
Hi karlsen, welcome.
Deleted files are moved to the recycle bin. I can restore them from there if you make a mistake. And it is easier to find the deleted files than with a rename option.
