Definitely worth the money to buy the licensed version.
I am a computer tech in Pensacola, FL USA and I repair anywhere between 10 and 30 systems per week. 90% of what I do is remove virus and spyware/malware infected files. Ultra Virus Killer has simplified my job immensely. I used to spend large amounts of time digging in the registry and finding infected files manually to get a system to the point where AV soft was even allowed to run. Then after that, even more time doing scans and updates.
Just a few minutes with UVK and you've knocked out 90% of your problems. And the built in third party scan software downloads make cleaning the PC the rest of the way easy. Thanks for creating a wonderful tool Fred. Your Software is much appreciated.
I highly recommend Ultra Virus Killer.
-Brink
http://fixmefaster.com/
Vicelord
Re: Definitely worth the money to buy the licensed version.
Post by Vicelord »
agreed. I'm a computer tech from Gistel, Belgium. I love the versatility of this program, added a lot of third party scripts to the system repair section, from installers with ninite to malware removal programs. It's very easy to have a single program from where you can launch al your installers which are directly downloaded from sites (always the latest versions!). I use this program daily :)
I agree UVK makes things so much easier. There are lots of things you can do with it.
