[SOLVED]<EmptyBrowsersCache> except cookies?
scottay
Post by scottay »
Is there a way to run the <EmptyBrowsersCache> command but ignore cookies?
That function does exactly what I need it to, but I like to leave cookies on my clients' systems.
Thanks again!
Re: <EmptyBrowsersCache> except cookies?
Hi Scottay.
Thanks for your posts, you've been a great help debugging UVK.
I've just looked at the code. UVK deletes the cookies only for IE, not other browsers.
Don't ask me why I did it this way cause I can't remember. Maybe at the time I thought it was the right thing to do.
I'll remove the IE cookies deletion from the function, and create a new one: Delete all browsers cookies.
I will be available on the next update.
Ok, the new version 2.5.0.0 was released.
Now the Empty all browsers cache fix only cleans the cache and leaves the cookies alone.
The new fix Delete all browsers cookies deletes the cookies for all installed browsers.
Enjoy!
scottay
Post by scottay »
Perfect, thanks!
