I want to get a list and delete some old programs, programs(old versions, etc) that don't show up in anything to uninstall them?
with the command processor...
Run as admin
wmic
product name get
gets a list of the programs and then the verbose hard work begins...one at a time....
Is there a way UVK can do this better?
Emulate the command processor?
Re: Emulate the command processor?
Hello,
UVK has the Cleanup MSI orphan files fix, in the System Repair module. That probably does exactly what you want with almost no effort. If you need something stronger, try the Windows installer cleanup, in the Tools and tweaks module. You can select and remove several items at once.
