<UnzipFile> command
SAMEtechAndy
<UnzipFile> command
Post by SAMEtechAndy »
Hi,
I am having issues with the <UnzipFile> command not working. The zip file does exist in the ThirdParty directory and I can extract it manually. The %ThirdParty% variable is pointing to the correct folder.
When I run:
<UnzipFile>
%ThirdParty%\CrystalDiskInfo.zip
then it says it has successfully extracted the zip file, but it doesn't.
Strangely, if I copy the zip file to D:\Downloads and run:
<UnzipFile>
D:\downloads\CrystalDiskInfo.zip
then it says it has failed to extract the zip file, but it actually does extract it as expected
Andy
Re: <UnzipFile> command
Hi Andy.
Thank you for reporting this. I will release an update soon which will address this issue. Have a nice day!
