SimplySync Backup licensing
I see you have licensing for SimplySync set up now. Is it yearly licensing? Also, can you implement a pack of licenses? Also, will a free version remain as well?
Thanks, Bill
Re: SimplySync Backup licensing
Couple more things. Could you make the licensed version automatically check for and install updates and maybe email error reports after a backup is run or and there’s a program installation or update error?
Thanks, Bill
Hi Bill.
SimplySync licenses are lifetime valid. However, they are OEM based (1 machine per license). I will add the license pack purchase page ASAP. How many licenses should the pack have? Three? Maybe five?
Once activated with a license, automatic updates are enabled (unattended). I will try to add a reporting feature in the next update.
I will need 4 for sure so a five pack would be a good number. You decide and I will work with what you come up with. How would you feel about a way to deactivate a license in case one needs to switch machines or hard drive etc.?
Thanks! :D
