pc 3: portabilized Win 10 x64 Windows To Go Workspace on Kingston Datatraveller Workspace
tate-datwin
Post by tate-datwin »
Hi all,
My portabilized Win 10 "Windows To Go Workspace" installed on Kingston USB disk are also infected and contains bugs and errors:
OS: Win 10 X64
Storage of Windows To Go Workspace: 60 Gb
Antivirus: COMODO Cloud Antivirus + iObit Malware Fighter Pro Giveaway
1: very slow, freezes/bugs/crash on explorer, takes long time to execute an app
2: Winsweeper by Solvusoft portable version installed of root directory of Windows To Go workspace
3: error message displayed in deutsch in UCheck By Adlice, please view the screen capture below
4: The Kingston portabilized Windows Workspace's drive detected only in the desktop compaq pc's uefi only, but not detected on Galaxy Book's UEFI
heres the logs of differents apps and diag tools below:
https://www.cjoint.com/c/IAgpNei65jC
https://www.cjoint.com/c/IAgpK4cA4WC
https://www.cjoint.com/c/IAgpO2JSQBC
https://www.cjoint.com/c/IAgpQqDtmDC
https://www.cjoint.com/c/IAgpV2pc1iC
usb file resc log for the Kingston Workspace (launched from the Pc 1: Galaxy Book)--: https://www.cjoint.com/c/IAiiUXhlyfC
Thanks...
tate-datwin
Re: pc 3: portabilized Win 10 x64 Windows To Go Workspace on Kingston Datatraveller Workspace
Hi Fred & others helpers,
Glary Utilities can't get rid of "read only" on fat32 disks,
heres below the Ultra Adware Killer & UVK logs,
Thanks...
Ultra Virus Killer log.txt
(1.72 MiB) Downloaded 432 times
uak kingston workspace scan log.txt
(29.04 KiB) Downloaded 478 times
uak kingston workspace cleanup log.txt
(14.58 KiB) Downloaded 446 times
Hi tate-datwin.
The cleanup operation seemed to work well but you need to reboot the PC for it to complete.
Otherwise, how's the computer running?
tate-datwin
Fred wrote: Tue Jan 15, 2019 9:20 pm Hi tate-datwin.
always the same bugs:
more one another/5th bug:
5: 2Gb free space only
thanks...
tate-datwin,
Please save the attached UVK script (tate.uvk) to your desktop. double-click the saved file, which should automatically be loaded by UVK. Press Run script and confirm. UVK will run the script and then reboot your computer. That will remove Winsweeper and make some extra cleanup and repair. Hopefully your machine will work better after the reboot.
If your storage device is a HDD (not a SSD), it may be failing. That would explain the slowness and Explorer bugs. In that case, I would advise you to backup your data, replace your HDD with an SSD and install Windows 10 on it.
You also seem to have tried many malware removal tools in your machine, and some of them may have done permanent damage to your OS. A fresh Windows install could be the best choice for you.
Either way, backing up your data is always a wise choice, especially before running the attached script.
tate.uvk
(5.38 KiB) Downloaded 426 times
tate-datwin
this pc is a portabilized Windows installed on Kingston dataTraveller USB Disk, it's like a ssd,
for the real desktop pc (Windows 8) and tune-up dualboot/xubuntu live usb/sardu usb/cubuntu live's virtualbox/"EFM, Barrow 16,2 & Widen 16" folder on 5 Tb external Seagate hdd/others usb drives/1 Tb micro sd (to get rid of boot errors, and others errors/bug), please report on the topic below:
viewtopic.php?f=8&t=2044&sid=f47c6bb5b4 ... 6c34a66185
i had executed the "tate.uvk" today,
Thanks...
