[Solved]SmartInstaller White/Black List Not Syncing
allanc
Post by allanc »
The symptoms from this viewtopic.php?f=4&t=1628&p=7641&hilit=whitelist#p7641 thread of Feb. 2017 have just resurfaced.
I have re-read the prior thread and do not remember how we resolved the issue.
Sorry.
Allan C.
Re: SmartInstaller White/Black List Not Syncing
Allan, I took the liberty to test using your license and could not reproduce your issue so far. I added and removed items to both the white and black lists, they had been correctly synced. I'll run some more tests and keep you up to date with the results.
allanc
Post by allanc »
Fred wrote: Fri Jan 04, 2019 7:59 pm Allan, I took the liberty to test using your license and could not reproduce your issue so far. I added and removed items to both the white and black lists, they had been correctly synced. I'll run some more tests and keep you up to date with the results.
By the way, In my post that started this thread, I linked to another post of mine with exactly the same symptom.
I do not think that you could replicate the problem back then either.
I do not remember how you resolved the issue and the original thread was not updated with the resolution.
I am having another problem which may be related and might assist you in the diagnosis.
I cannot edit any of the items that I created in the System Repair module.
The menu lists 'Edit Highlighted App'' but it is disabled.
I hope that this helps.
One last thing is that when I click the 'X' in the top right hand corner, I am not prompted to uninstall UVK.
Perhaps these are all connected - I do not know.
Thanks Fred!
Allan C.
Allan,
Please try the following:
  • From UVK's Smart Uninstaller, uninstall your Proven solutions repair tool, but when prompted to make a clean uninstall, click Yes.
  • Download the latest UVKPortable.exe to the usual location.
  • Place your key.uvkey license file in the same location.
  • If you have a UVKSettings.ini file in the same location, move it to a different folder (important).
  • Launch UVKPortable.exe, and when prompted to enable cloudsync, click No.
  • Go to the Options section and set your desired settings, such as the running password.
  • Then, click the Cloud Sync button and then, first of all, click the first Upload now button from the top.
  • Set the desired cloudsync options and then click OK, I'm done.
If this does not solve your issue, then it is probably related to your machine, I may need to remote again in order to diagnose the problem.
P.S. As for the custom third party apps issue, there is no SR_Settings cloud synced so I could not test. You may need to upload your settings first.
allanc
Post by allanc »
Fred wrote: Sat Jan 05, 2019 11:47 am Allan,
Unfortunately, your steps above did not resolve my issues.
Thank you for trying.
Allan C.
allanc
Post by allanc »
allanc wrote: Sun Jan 06, 2019 11:46 pm
EDIT:
I also tried the steps above on another computer with the same results.
Allan C.
Allan, please let me know your availability and timezone, so we can schedule a remote session.
allanc
Post by allanc »
Fred wrote: Mon Jan 07, 2019 6:48 pm Allan, please let me know your availability and timezone, so we can schedule a remote session.
Eastern Time Zone (Toronto Canada - like New York) - It is 1 pm now.
I will be available at 2 pm.
If you want to use TV (like last time) I will need your pm address.
Tks.
Allan C.
OK for 2 pm. You can send me private messages here in the forum or to fred( AT )carifred.com. We can also use TrustViewer instead. It's free even for non commercial use. http://www.trustviewer.com/en
If we do use trustviewer, it's better if you install it in the target machine, and not use the portable version, which does not work well with the UAC.
Allan I've got both Teamviewer and Trustviewer ready. Waiting for your PM with the authorization code.
allanc
Post by allanc »
Fred wrote: Mon Jan 07, 2019 7:58 pm Allan I've got both Teamviewer and Trustviewer ready. Waiting for your PM with the authorization code.
Hello Fred,
Do you think that you may have the opportunity to update the site with a new build by this weekend?
Thank you in advance.
Allan C.
allanc wrote: Fri Jan 11, 2019 11:42 am Hello Fred,
Of course. I've been adding a new checkbox in the Options section that allows us to manually enable/disable the uninstall prompt when the application is closed. I will try to upload the new build today.
allanc
Post by allanc »
Fred wrote: Fri Jan 11, 2019 7:25 pm
Thank you.
Great service!
Allan C.
This topic has been solved and a new update was released. The main issue was that a bug was preventing CloudSync from uploading files.
Also, thanks to a different issue reported by Allan, I added a check box to control whether to display a dialog box asking you if you want to uninstall UVK, when you close its last running instance.
I also created a new topic that allows you guys to get notifications when a new build is available. This was requested by Allan, too.
viewtopic.php?f=5&t=2046&p=8720#p8720
allanc
Post by allanc »
Thank You Fred.
Allan C.
