Run ComboFix in script?
netmonk99
Post by netmonk99 »
Is it possible to download, update and run ComboFix as part of a script in UVK?
Re: Run ComboFix in script?
Well, download and run combofix as part of a script should be easy, but the author doesn't approve it.
At least that's what bleepingcomputer told me when I had it automated in the automatic anti-malware scans. They had me remove it.
But I guess for a private script it should be OK:
netmonk99
Post by netmonk99 »
Would you mind PM'ing me the script for it, if you don't want it posted publicly?
Thanks!
It's really no big deal, netmonk99. You just have to often check if they have changed the download url.
 <Download>
http://download.bleepingcomputer.com/dl/6d336c2bc7b73a36ac8e3ea720fab839/4fd064c1/windows/security/anti-virus/c/combofix/ComboFix.exe | %Temp%\CmboFx.exe
 <RunWait>
%Temp%\CmboFx.exe
If the combofix process ends before the end of the scan, the script will also continue before the end of the scan, which may not be desirable.
Also, combofix usually restarts the machine automatically, so I think you should leave the combofix scan for the very end of the script, and don't use the <Reboot> or <Shutdown> commands.
I just noticed they still use the 10 minutes download link. I was hoping they had removed it.
The download url only works for 10 minutes. I guess you'l have to download it manually and put it in a portable media device.
