I don't know either it is a bug or new feature but I didn't find the disable option in autorun manager.
It is good if we have enable and disable feature.
For quick reference:
In UVK -----------> we can only delete.
In msconfig ------> we can enable or disable.
In ccleaner ------> we can enable or disable or delete.
Disable Autorun entries
- CCleaner autorun -3.png (39.72 KiB) Viewed 7646 times
Re: Disable Autorun entries
Deleted autorun entries can be restored by clicking Create/Restore, so deleting an entry is basically the same as disabling it. The same thing can be said about the Service manager.
Backups of the deleted items are permanently removed if you perform a Clean uninstall of the application, or if you manually remove them. This means you can restore deleted autorun entries and services even after uninstalling UVK.
Got it.. thanks
