Start menu
Start menu
Since the last update the tile removal on the start menu does not work at all now.
Re: Start menu
You're right, Jim. Just fixed it, should be good in the next update.
Re: Start menu
Has working version of this been put out yet? The notes from last release did not mention it so I just wanted to check.
Re: Start menu
Hi Jim. Yes, it was fixed in the latest update.
