The memory count is way off here. Not sure how much I can help other than this as the customer is coming in a little while.
[ Memory (RAM) devices ]
Total physical memory=-257 bytes (-25769803776 bytes)
Memory device 0=Capacity: 2 GB Type: DDR2-800 PC2-6400 Speed: 800MT/s
Memory device 1=Capacity: 2 GB Type: DDR2-800 PC2-6400 Speed: 800MT/s
Memory device 2=Capacity: (Empty slot) Type: DDR2-400 PC2-3200
Memory device 3=Capacity: (Empty slot) Type: DDR2-400 PC2-3200
Memory device 4=Capacity: -300 bytes Type: FLASH
RAM is off
RAM is off
Re: RAM is off
Thanks, Jim.
It seems to be caused by the flash drive that's being used as RAM aux. I'm going to try to reproduce and fix this.
