tech tool store bugs
whiggs
Post by whiggs »
I didn't see a forum for tech toolstore, so I figured I would report the bugs here so that they can be fixed. There are (that I have verified, there may be more) a couple of entries in the tech tool store which aren't working as they should. I have confirmed this on multiple devices. It actually looks like one of them (path my pc) has been fixed already. But nirsoft nirlauncher suite remains broken, displaying "This app can't run on your pc" when one attempts to update and run it.
Re: tech tool store bugs
Hi Whiggs. Thanks for reporting this. The Nirlauncher zip archive is now password protected. When was the first time you saw that happening, can you tell?
whiggs
Post by whiggs »
Ah. So it is. That is interesting. I personally do not remember exactly when it started, but I use the toolstore to run the package everyday for work, and considering nirlauncher was updated on March 4th, 2018, I would say that it would be a safe assumption to assume that is when the developers decided to password protect the archive.
Thanks. Anyway, the issue was fixed yesterday . Should be fine now.
