Uninstall UVK creates empty folders
TheLaptopFixers
Post by TheLaptopFixers »
I use a script to robocopy UVK from a NAS drive to a temp folder on C:\uvkTemp.
robocopy "%ScriptPath%" %UKVPathTemp% /MIR
Then this script is run to install UVK:
START %UKVPathTemp%UVKSetup.exe -Silent -Auto -NoRP -NoCMenu -NoRun -Customdir "%UKVPath%"
REM DELAY FOR 2 SECS (value of 3 because first PING takes 1 sec to complete)
ping 127.0.0.1 -n 5 > nul
IF exist "%UKVPathTemp%uvksettings.uvksr" (
ECHO LOADING SCRIPT: %UKVPathTemp%uvksettings.uvksr
ECHO %UKVPath%\UVK_en.exe
START %UKVPath%\UVK_en.exe -ImportSr "%UKVPathTemp%uvksettings.uvksr"
) ELSE (
ECHO ** FAILED ** NO SCRIPT FOUND = LOADING TOOL PLEASE LOAD UVKSETTINGS.UVKCR MANUALLY
PAUSE
UVK runs and the Temp folder is removed.
However, when I run "Uninstall this Application" the Temp folder is put back which I presume if from the uninstall procedure.
Not a big issue, but nice to clean up the folders on completion 100%.
Re: Uninstall UVK creates empty folders
Hello, thanks for reporting this. I'll make sure it no longer happens in the next update.
This issue should now be fixed in version 10.7.9.1. Thanks again for the bug report.
