UVK Scripts - variable for drive letter
SAMEtechAndy
Post by SAMEtechAndy »
Hi,
Is there a way I can specify a program to run that is outside of the %InstallSourceDir%. I would like to run a program that resides in another directory on the root of my flash drive, but cannot of course guarantee the drive will get the same letter in every system I use it on, so I'm looking to capture the drive letter.
Andy
Re: UVK Scripts - variable for drive letter
Hi Andy.
You can use %InstallSourceDir%\.. to specify the parent directory of %InstallSourceDir%. Use %InstallSourceDir%\..\.. to specify the grand parent and so on.
Let's say %InstallSourceDir% is in F:\UVK. If you want F:\cCleaner.exe, specify %InstallSourceDir%\..\cCleaner.exe.
Hope it makes sense.
SAMEtechAndy
Many thanks Fred
