Windows 7 Offline update
Muhammad Tasneem
Post by Muhammad Tasneem »
Hi,
Is anyone know from where to download latest windows 7 Convenience Rollup Package?
Here is my procedure:
  • Install windows 7 with SP1 DVD/USB.
    than apply Convenience Rollup (KB3125574).
    than use WSUS_offline for current updates.
I want to reduce the time on third step.
Is there any yearly/monthly Convenience Rollup Package for windows 7...?
Re: Windows 7 Offline update
Hi Muhammad.
Tech Tool Store does that for you. Search for Windows 7 KB3125574 rollup.
Muhammad Tasneem
Thanks Fred,
Will try Techsuit,
On second step, already using KB3125574 roll up. This roll up only update till April 2016.
Than on third step using wsus offline, which install all updates till date, but it takes time and multiple reboots.
I just want to know does MS release any monthly or annually roll ups?
Muhammad Tasneem
Fred, Does Tech Tool Store install Windows updates offline?
Normally I am updating WSUS (in my USB-HDD) once in a month.
Muhammad, currently, TTS only installs 3 updates for Windows 7. They are meant to fix the slowness of Windows 7 SP1 clean installs when searching for updates. WSUS is also part of the tools included on TTS.
http://www.carifred.com/tech_tool_store/
The latest Windows update roll up is probably KB3185278. A quick google query can tell you that.
Muhammad Tasneem
Thanks for your tip.
I think, I am too old to learning ... I have again reading all my saved articles/web pages and found what I have missed.
I was following this link to make updated media (but not always use).
Windows 7: Creating Fully patched Image by Slipstream in the Convenience Rollup and Quality Rolluphttps://social.technet.microsoft.com/wi ... ollup.aspx
Step # 1
Installing windows 7 SP1 from original media
Step # 2
After installing Win 7 SP1, I always install these three updates.
KB3020369 - http://catalog.update.microsoft.com/v7/ ... =KB3020369
KB3125574 - http://catalog.update.microsoft.com/v7/ ... KB3125574
KB3185330 - http://catalog.update.microsoft.com/v7/ ... KB3185330
Step # 3
Run updated WSUS Offline Update http://download.wsusoffline.net/
Now I realized that instead KB3185330, I only need to install the latest Security Monthly Quality Rollup or in-short Monthly Rollup
Here is the procedure which I have found:
Write down the latest "Monthly Rollup" number from this link:
Windows 7 SP1 and Windows Server 2008 R2 SP1 update history:
https://support.microsoft.com/en-us/hel ... te-history (like for month of September 2017, it is KB4038777)
than search and download files from here:
Microsoft Update Catalog
https://www.catalog.update.microsoft.com/home.aspx
avinash
Post by avinash »
Thanks for sharing information. It is very helpful.
RenukaGupta
Post by RenukaGupta »
Great information was very useful for me.
Artificial Intelligence Course In Hyderabad
