immunizing the system seems to mess up Firefox and possibly chrome add-ons. It does prevent adding add-ons but once you disable immunization you still can't until you completely reset Firefox.
I have known about this bug for a while but had not confirmed it was a bug till now.
Also, in the repair section you have "Prevent reboting until all is done." The "reboting" is mis-spelled.
Firefox add-ons
Firefox add-ons
Re: Firefox add-ons
Thanks, Jim. I'll look into that ASAP.
Re: Firefox add-ons
Just wanted to drop as quick note that should help you out tons....
I just discovered that if you start UVK then disable the immunization through it, you can then add add-ons just fine. So, it appears to be a bug in your stand alone tool.
Re: Firefox add-ons
Oh, that surely helps, Jim! Thanks.
Stay safe.
Stay safe.
Re: Firefox add-ons
Nailed it! Will be fixed in a new update I will release today or tomorrow.
Re: Firefox add-ons
Fred, You know your 7.1 update is broken right? It appears the new EXE is not there but the update file is telling UVK it is there.
Re: Firefox add-ons
Hi Jim. Yesterday I thought I had uploaded everything, so I increased the version indicator. But I actually had not uploaded any of the EXEs. It's fixed now, you guys just need to update. Thanks, Jim.
