Repair shopr
Repair shopr
The last couple times I have tried sending reports to RS I fails with a message about there being no domain for RS.
I have filled in all the info and it shows when the dialog is open but it only refers to a subdomain and not a domain like UVK reports is the failure.
Re: Repair shopr
Hi Jim.
If it says "RepairShopr's domain not specified.", what it really means id "RepairShopr's sub-domain not specified.".
If you are correctly indicating your RS sub-domain, then it is a bug. I think I just found it, and it should be fixed in the next release.
Re: Repair shopr
Sounds good, I'm glad you were able to identify it quickly.
