Minor SFX issue
- Contact:
Minor SFX issue
When running the SFX archive UVKPortable.exe, two shortcuts will appear on the desktop, the branded and the UVK shortcut.
Re: Minor SFX issue
Thanks, virtualnetwork. I will fix that for the next update.
- Contact:
Re: Minor SFX issue
Thanks Fred.
- Contact:
Re: Minor SFX issue
Still getting two shortcuts on the desktop. And the tooltip shows the company name in duplicate.
Re: Minor SFX issue
Sorry about that. It seems I'll have to go dig deeper to figure out this one.
- Contact:
Re: Minor SFX issue
Still not resolved in v. 10.4.0.0. Will you fix this for the next update? And could you add an option to create a branded version of the SFX archive, perhaps with some auto-delete function so that customers won't be able to run it? Thanks.
Re: Minor SFX issue
This issue is now fixed in version 10.4.1. You also have a check box to enable branding the SFX package's icon.
Re: Minor SFX issue
I'm troubleshooting what might be a minor issue. Seems like sometimes it decompresses without its license/branding but the next time it doesn't. Looking for a pattern....
Re: Minor SFX issue
Working fine for me here. tested decompression more than ten times. Uninstalled first on most of them.
- Contact:
Re: Minor SFX issue
Thank you Fred. It's working well now. This will make it easier to deploy UVK remotely.
- Contact:
Re: Minor SFX issue
Xander, I haven't run into this issue. Did you uninstall and remove any remnants from previous versions?
Re: Minor SFX issue
It happened first on a remote PC and, later, on my host PC. I haven't been able to recreate it since.
Wouldn't 'remnants' have made it more likely that the licensing info/etc was present, not missing?
Re: Minor SFX issue
Maybe, maybe not. If the uninstall process was malfunctioning, there is no telling what remnants it would leave behind.
On the other hand, if the right stuff was left behind, you could very well be right.
- Contact:
Re: Minor SFX issue
Could it be that you were using an earlier SFX package on the two PCs where it happened, but can't recreate the issue with a new SFX package?
Re: Minor SFX issue
I run a scheduled batch to create a new one every morning so unless it was from the version immediately before it....
