SimplySync Backup & computer pass worded
Would it be possible to allow the screen saver or however the computer locks while using SimplySync Backup?
Re: SimplySync Backup & computer pass worded
Hi Bill.
I can add a setting for that. Thanks for the request.
Thanks Fred! :D
Bill, just released new version 1.3.1, which should be doing as you asked. Also allows to backup entire volumes and supports copying more files, including symbolic links.
Sorry for the delay.
Thank you Fred. Much appreciated. :D
