Some script aspects not firing
Post by Xander » Thu Jan 26, 2017 4:55 pm
Fred, I've finally got some time to fine tune my 'quick tuneup' script
<UVKCommandsScript>
<RunWait>
"\\nas\_uvk\third party\niniteone.exe /updateonly /disableshortcuts /allusers /cleancache"
;once this runs, I'll throw in the /silent parameter; it works as is from the Run box
<UAKScan> ;works
<MBAMScan> ;works
<AvastBCScan> ;doesn't work
<RogueKillerScan> ;doesn't work
<TDSSKillerScan> ;doesn't work
<AswMBRScan> ;doesn't work
<AdwCleanerScan> ;doesn't work
<SASScan> ;fires up but it's only here for testing, I don't use it
Any suggestions on what might be wrong here? I tried throwing another "<UVKCommandsScript>" in front of the scans but that didn't help.
Re: Some script aspects not firing
Post by Fred » Thu Jan 26, 2017 5:17 pm
Hi Xander.
Your script seems fine. The third party scans from script use the same functions as the System repair section, so if something is wrong, it must be in the script parser.
I'll test that out. Thanks for reporting
What is the hardest thing to develop? A good application? A good website? Nope. A good reputation.
Vove
Post by Vove » Wed Jan 09, 2019 12:57 pm
Hi Xander.
Thank you for this answer! Had the same issue!
