What is this??
What is this??
This dialog has popped up a couple times right after first running UVK.... Is it supposed to? Is it a bug? What is is it...
Re: What is this??
Hi Jim.
Honestly, no idea. How do you know it is related to UVK?
Re: What is this??
I don't know for sure but I've only noticed it while using uvk. It's happened a couple times and I can't think of anything else it would be. If you don't know them next time I see it I'll try to figure out is owner for sure.
Re: What is this??
Jim you can use the Process manager's Window catcher to get the process that is displaying that message box. I can tell for sure it is not UVK. I never coded such message.
Re: What is this??
I believe you but that's really odd. I'll let you know what I find out Incase it is somehow related to uvk.
Re: What is this??
Well, the message could be displayed by UVK's process if it came from an AutoIt or VBS script included in a UVK script. But in that case, I guess you'd not be surprised, right?
Re: What is this??
Yea, that's the baffling part. It looks like a confirmation dialog from a script but I have not set any startup scripts and most of the scripts I made, you actually added to uvk anyway so that don't make sense either.
