I have just read this and think it is good if it will add in UVK .
Set Ethernet Connection as Metered in Windows 10
Source:
http://www.winhelponline.com/blog/ether ... tmediacost
I think it is good if we have a separate section/tab for windows feature enable/disable.
Re: Set Ethernet Connection as Metered in Windows 10
Maybe add the option to the “Tools and Tweaks, “Registry Tweaks” section. I’m not sure how many would need this though. Is a metered connection common these days? I’m just asking. I’ve never run into anyone with a metered connection.
I think this may be a good idea.
Bill, nice thought, the Registry tweaks is a great place for this. People use metered connections often these days, when they travel, and connect their PCs to the internet by using their phones as access point. They rarely use metered connections through Ethernet, though. I guess that is why Windows does not have the option.
This makes perfect sense now that you say that. When I was erecting steel I used my cell phone all the time for an internet connection. It was often faster than the wireless at the hotels we stayed at and although I’ve always paid for unlimited data, I know many who don’t. It just cost too much. I should review my cellular plan. I wonder how much I actually use these days.
It is good to Add a "Windows Tweaks" Section In which you can make groups like OS related Win 10, Win 8.x Win 7 and General group which can apply on all OS.wmmiller wrote:Maybe add the option to the “Tools and Tweaks, “Registry Tweaks” section.
Here is another article (just for info) which I have read few times before.
Improve Windows 10 with one-click batch files
http://www.ghacks.net/2016/11/08/improv ... tch-files/
The 50 Best Registry Hacks that Make Windows BetterThe following batch files are included in the archive
1.Advanced Explorer Settings -- This changes more than a dozen File Explorer related settings on Windows 10 that turn of animations, enable menus, or turn off things like Toasts.
2.Disable Automatic App Updates -- Turns off automatic updates for Windows Store applications.
3.Disable Automatic Windows Updates -- Turns off automatic updates for the Windows 10 operating system itself.
4.Disable Cortana Completely -- Rename the cortana process searchUI.exe to searchUI.bak. This will kill the process permanetly and save your ressources.
5.Disable Forced Reboot after Update -- Blocks Windows from enforcing a reboot after updates that require one.
6.Disable Lockscreen -- Turns off the Windows 10 lockscreen.
7.Disable Telemetry -- Turns off Windows 10 Telemetry.
8.Disable Unnecessary Services -- This disables the MapsBroker, DoSvc and Wsearch services
9.Enable Defender Malware Protection -- Enables Windows malware Protection.
10.Enable Secure Microsoft Edge Settings -- Tweaks Microsoft Edge for security. Changes include turning of Flash and Cortana, enabling continuous browsing, and more.
11.Get Back Old Vertical Desktop Icon Distance -- Changes the vertical icon spacing on the desktop.
12.Hide Cortana -- Disables Cortana, and with it web searches and other search related parameters. The Microsoft way of disabling Cortana.
13.Hide OneDrive -- Hides OneDrive and disables several related settings.
14.Re-enable Cortana Completely -- This preferences turns Cortana on again.
15.Uninstall Unnecessary Apps -- Removes ten apps that Windows 10 ships with including 3D Builder, Skype App, Getting Started, or Voice Recorder.
16.Enable Administrator Account -- This preference enables the hidden administrator account in Windows.
17.Enable Standby instead of Hibernate -- Switch powerstate from hibernation (slow) to standby .
18.Get apps access for Administrator Account -- Enable access to applications for the administrator account
http://www.howtogeek.com/howto/37920/th ... ows-better
Windows Tweaks Guide - GEGeek
http://www.gegeek.com/tech_reference/ho ... 0Guide.pdf
Tweak Guides by TweakHound
https://tweakhound.com/tweakhounds-tweak-guides
Comparison of Windows 10 Privacy tools
http://www.ghacks.net/2015/08/14/compar ... acy-tools/
I also found a simple and free utiliy fo windows Tweak is Ultimate Windows Tweaker from TheWindowsClub.com
Ultimate Windows Tweaker 4 for Windows 10
http://www.thewindowsclub.com/ultimate- ... windows-10
Ultimate Windows Tweaker 3 for Windows 8
http://www.thewindowsclub.com/ultimate- ... -windows-8
Ultimate Windows Tweaker 2 for Windows 7
http://www.thewindowsclub.com/ultimate- ... ws-7-vista
Fact is UVK is best of all but need to add some more tech items to make it The One and Only App a tech guy need.
Just read the benefits of Metered Connections, good to read:
Disable Windows 10 Updates Post Anniversary Update 2016
http://www.rizonesoft.com/disable-windo ... ry-update/
Windows 10 Update Switch
http://www.rizonesoft.com/downloads/win ... te-switch/
