Hi forum,
I am trying to create a fully automatic cleaning script.
The part where I am stuck at is Google Chrome.
I use the Control Info Tool to click buttons etc. but in Google Chrome I have to use x and y coordinates.
The problem with this is that I use the script on PC's and laptops with different screen sizes, therefore the x and y coordinates are different.
Is there any way to open chrome in a fixed window mode using UVK?
Thanks in advance,
Martijn
Open Chrome in windowed mode
Re: Open Chrome in windowed mode
Hi MartijnH.
The only thing that made it work for me was this:
"%Programfiles(x86)%\Google\Chrome\Application\chrome.exe" --app="data:text/html,<html><body><script>window.moveTo(100,100);window.resizeTo(800,600);window.location='http://www.carifred.com';</script></body></html>"
Thanks for the quick response Fred!
Your script works fine indeed, the only problem for me is that the button to get into Chrome's settings is gone.
Is there a way to make that button stay? (I tried bypassing the button by changing the url to chrome://settings but that doesn't work.)
Thanks in advance,
Martijn
Thanks in advance,
Martijn
Could not figure it out either. May I know why you want to open the settings page?
Yes, I want to reset the start page to the default one and then open the extensions tab automatically.
Sorry for the late reaction..
