How to remove unused network profile/List
Muhammad Tasneem
Post by Muhammad Tasneem »
How to remove unused network profile or List in Windows?
Is it possible to do it with UVK?
I have a Laptop which change its network one of old unused profile?
Re: How to remove unused network profile/List
Hello Muhammad.
Yes, you can use the Reset WLAN profiles and settings system repair fix, but that will remove all saved profiles. If you want to remove only specific profiles, there's a script here:
viewtopic.php?f=6&t=947
Muhammad Tasneem
Thanks Fred
I will check it tomorrow. just need to ask is this also works on wired lan or only wifi?
Muhammad, this is for saved WIFI profiles only. On wired LAN, connection usually works as soon as the cable is plugged.
