I am attempting to add my own automated 3rd party apps using scripts to the system repair section of UVK. Each tool has its own script file. I have been slowly making these scripts for weeks and they have all been tested extensively and work fine from the Log Analyzer. Now I am trying to add them and see it all in action but cannot get them to run without bringing up the "Run Script" screen.
In the documentation I read:
All of my scripts look something like this:Or you can create apps that run UVK scripts easily. You just need to specify the path of your script in the command. Append -Auto if you want to run the script without confirmation. Side note: I can execute the scripts from the "Run Script" screen and they work as intended but it kinda defeats the purpose of automation if I have to do that for each App/Program.
%InstallSourceDir%\My script.uvk
%ThirdParty%\My script.uvk -Auto
%ThirdParty%\script.uvk -Auto
However this still brings up the "Run Script" screen.
I have also tried:
"%ThirdParty%\script.uvk" -Auto
"%ThirdParty%\script.uvk -Auto"
%ThirdParty%\script.uvk /Auto
"%ThirdParty%\script.uvk /Auto"
"%ThirdParty%\script.uvk" /Auto
%ThirdParty%\script.uvk -auto
"%ThirdParty%\script.uvk -auto"
"%ThirdParty%\script.uvk" -auto
I have tried on two different computers, although they are both running Windows 10 64 bit.
What am I missing here? Or is this just a bug? I find it hard to believe that nobody else is missing this functionality!
Thanks in advance for any solutions.
