I launched Ultra Adware Killer and I guess I ended up checking things the opposite of the results I wanted. Now all of my apps that I though I was cleaning are gone! Is there a way to undo? I have not restarted or exited the app yet.
Help!
How to undo Ultra Adware Killer
Re: How to undo Ultra Adware Killer
Hi MDeath.
By default, UAK creates a system restore point before the cleanup. If you didn't uncheck that option, all you need is to restore the computer to the created restore point.
I did not uncheck create restore point but I find no restore files.
Thanks,
Thanks,
You need help on to use the system restore?
