Reboot or uninstall not always working
My SR setup ends with Uninstall UVK/Defrag Reg/Reboot PC but the three commands don't work together.
As far as duplication, here's what happens:
(I'm simplifying the list to just Cancel Chkdsk/Cancel Memcheck just to put some commands ahead of the very last section)
* Cancel/Cancel/Uninstall/DefragReg/Reboot = reboot but no uninstall. Same if I leave off the last Reboot.
* Cancel/Cancel/Uninstall/Reboot = uninstall but no reboot
The DefragReg command initiates a reboot by itself so having the Reboot command after it may be superfluous but that shouldn't supercede the Uninstall command, right?
This is in the Autoit/official version. If I run the new C++ version from my NAS (since there's not yet a Portable version), it loads at lightning speed(!) and, in the first example, does not reboot (and, since it doesn't 'install', I can't say if that step would be running correctly).
Re: Reboot or uninstall not always working
Thanks for reporting this again, Xander. I did work on this issue, but it seems I didn't fix it properly. I'll check it out again.
