List of installed software in the main report?
Tried searching to see if this had already been requested but the words "installed software" were considered too common to allow results....
The subject says pretty much all. Would be nice to be able to refer to a list of installed software later with version numbers -- basically the same list that comes up in the Uninstaller section.
Re: List of installed software in the main report?
Hi Xander. Thanks for the request.
I added that feature to the C++ UVK, I don't think I'll add it to the Autoit version, to not waste any precious time, since the C++ build is nearly ready.
