Rogue Killer
Rogue Killer
I think it might be a RK issue but the last few versions of UVK get hung up waiting for RK to finish. If I kill the process manually UVK will continue right along but if not it will wait indefinitely.
Re: Rogue Killer
Thanks Jim. RogueKiller now leaves a process in the background. I'll have to change the way automation works.
Re: Rogue Killer
You also mentioned that it was your intention to automate all the built in apps. I can't remember the last time I have not had to click through RK to get it going. Is this intended behavior? If so, don't worry about it, I just thought at one time you said they were all supposed to be automated.
Re: Rogue Killer
It was working the last time I tested. Automation is not an easy thing. Clicking, dragging or even just moving the mouse can sometimes break it. I'll test it out tomorrow before uploading a new release.
