How do you guys handle Windows 10 safe mode wireless networking?
Re: Windows 10 safe mode wireless networking
I'm not sure what you mean Bill?
It doesn't work in Windows 10
Well it does work but doesn't connect automatically.
You can try to run netsh connect
https://technet.microsoft.com/en-us/lib ... k_wlanConn
Or you could use the WLAN profiles manager to connect.
viewtopic.php?f=6&t=947&p=2885&hilit=wl ... ager#p2885
Ok. I should have said on a remote reboot. If I have the computer I just plug it in.
Never seen this one, I'll give it a try, thanksFred wrote:Or you could use the WLAN profiles manager to connect.
While performing an SR task?wmmiller wrote:Ok. I should have said on a remote reboot. If I have the computer I just plug it in.
If so, just add a 3rd party app with a netsh connect command after "reboot in safemode with networking" and it will connect before to continue.
On a side note (nothing to do with safemode but it could be usefull for you or anybody else, even in this case), to be sure i'm always connected before launching uvk (and because i'm lazy and don't want to do it manually ^^) I always start uvk by launching a batch file with that code on it :
SETLOCAL enabledelayedexpansion
FOR /f "tokens=2 delims=:" %%i in ('netsh wlan show interfaces ^| findstr /i /c:"Nom"') DO (
SET inter=%%i
if EXIST "%~dp0wlan.xml" netsh wlan add profile filename="%~dp0wlan.xml" interface="!inter:~1!"
PS: oh, and you probably would have to modify "Nom"' by "Name" (or what it is called in your language
Thanks guys. What a pain in the butt.
Thanks Microsoft. Not so much.
