How can i know/verify the %InstallSourceDir%?
Muhammad Tasneem
Post by Muhammad Tasneem »
UVK already installed on computer, I want to know what was the %InstallSourceDir% (from where I was installed the UVK) and I want to change it.
How can I do this?
On one PC when I update the UVK, its create a folder (which I believe that was the %InstallSourceDir% on that PC) but after updating it does not delete that folder and UVK installer.
Re: How can i know/verify the %InstallSourceDir%?
Muhammad, you can get the current %InstallSourceDir% from the IT/Geek tools and tweaks section.
Int the run input, type %InstallSourceDir% and press Enter. The path will be expanded in the input box itself, and the corresponding folder will also be opened in the Windows file Explorer.
I can not make UVK's uninstaller remove %InstallSourceDir%, because there may be files in that directory that should not be deleted, but I can make it delete the UVK installer.
Muhammad Tasneem
Is there any possibility to change the %InstallSourceDir% ?
Muhammad Tasneem
Fred wrote: I can not make UVK's uninstaller remove %InstallSourceDir%, because there may be files in that directory that should not be deleted, but I can make it delete the UVK installer.
Normally it is good not to delete the folder but as in update process (like in auto update feature) it should be deleted or it can be download in tmp folder and update from there.
