RogueKiller doesn't run automatically
It looks like Rouge Killer prompts user to install instead of auto-installing.
Re: RogueKiller doesn't run automatically
So it seems now it is install only. Thanks for reporting.
http://www.adlice.com/documentation/rog ... mentation/
What do you guys suggest? Automate install or use the console version?
http://www.adlice.com/download/roguekillercmd/
Looks like they still offer a portable version download.
http://www.adlice.com/download/roguekiller/
Portable sounds good. What are the benefits of console version? Fully automatic? (this would be my preferred one if this is the case - the less clicks the better!).
I use the tech license of it myself. One of the few apps I have purchased a license for. I would consider purchasing one for Hitman Pro but their license plans is carzy expensive.
You're right, Bill. The portable version is still there. I just uploaded the download urls and it seems to be working fine now. You guys just need to re-launch UVK, and if should be fine.
So UVK loads tool URLs dynamically now? How long has it done that? It's a cool idea.
Jim, the online URL update has been there for several years now.
When UVK is launched, it downloads a small INI file called "urls" from this server. That file contains the URL and link text for most of the downloads the application makes. this allows us to update a URL that has been changed without the need to update the whole application.
Good deal Fred
