Restore Normal Boot prevents checks before it
Still experimenting with what does and doesn't work in the last section but, normally, I have the following checked:
* Create Post-repair restore point (working)
* Send Reports (working)
* Uninstall the Application (not working)
* Defrag Registry if needed (seems to be working)
* Reboot the PC (not working)
* Restore normal boot (prob working)
At the end of a Repair set, the PC isn't rebooting and isn't uninstalling itself. If I check just the three bolded items, nothing effectively happens. If I check only Uninstall and Reboot, it does uninstall but does not reboot.
7.9.0.0
Re: Restore Normal Boot prevents checks before it
Thanks for reporting this, Xander. I'll fix those ASAP.
Oops - hadn't realized I'd already reported this.
