TTS Classic Shell Installer Fails
When installing classic shell from Tech Tool Store to windows 8.1 and Automation is checked... (have not tried other windows versions) The installer reports that parameters are missing or required.
I just thought that you would like to know.
Re: TTS Classic Shell Installer Fails
Thanks, Brink. The command should have /Passive instead of /silent. I'll fix it ASAP.
