This fix does not seem to work. It does not seem to remove the icon. I just did it on another computer and that computer just asked me to upgrade.
Windows 10 Ugrade annoyance fix
Re: Windows 10 Ugrade annoyance fix
Currently it needs a reboot for the fix to be active. I'll make it be immediately effective in the next update.
Before posting that, I did the fix then restarted for other updates and it asked me to upgrade upon reboot. I can try again in the next day or so for a second opinion.
I uploaded a new debug build in which I addressed the issue. Let me know if it works, and also the system info, and I will release the update immediately.
http://www.carifred.com/uvk/UVK_debug.exe
Launch from UVK's install dir.
Thanks, Jim.
Thanks, Jim.
Did not get to test the windows upgrade part but the system info did not change. Since it locks the computer up while it's thinking I couldn't really do anything else.
