[Fixed] 7.8.0.1 crashing on System Info section
I just had a bug report saying 7.8.0.1 crashes when switching to the System Info section. Is this happening to anyone else? If so, does the PC have a SSD disk?
Also, does it also crash when you run the Defragment C: fix, from the System repair section?
Re: 7.8.0.1 crashing on System Info section
I tired both of those things on my own computer that has an SSD and it worked flawlessly. Defrag was skipped as it should be.
Thanks Bill. That's a great relief.
No problem on my own pc (with an ssd) while switching to system info section and no problem with defragment c: neither (the test is just skipped because it is an ssd)
ghandi
Post by ghandi »
I am having the same problem; previous stable version worked corectly. Windows is installed on a SSD and I have another one for data. I get this error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: UVK_en.exe
Application Version: 7.8.0.1
Application Timestamp: 5703b19a
Fault Module Name: StackHash_5883
Fault Module Version: 6.1.7601.19160
Fault Module Timestamp: 56bcd74c
Exception Code: c0000374
Exception Offset: 00000000000c0aa2
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
7.8.0.1 loaded the system info fine for me and I do NOT have a solid state.
Thank you all for your answers. ghandi, can you please tell when the crash takes place? Is it immediately after you click the System Info button, or is it a second or two afterwards.
ghandi
Post by ghandi »
@ Fred,
I have 'getting system info, please wait' displayed for 2-3 seconds with the busy indicator spinning and then get a 'UVK has stopped working' message box displayed. This feature worked fine with 7.7.2.0.
ghandi, I created a UVK build to help us bebug this issue. Since I can't reproduce it myself, it will help me to find out what is causing the application to crash.
If you don't mind to help out debugging this issue, please download this file:
http://www.carifred.com/uvk/UVK_debug.exe
The debugging procedure is very easy:
  1. Move the file to UVK's install directory.
  2. Run the file, and click the System Info button.
  3. Post, attach or PM me the contents of the Debug.txt file, in the same directory.
Thanks again.
System Info working here.
Defragment C: doesn't crash but, run separately, doesn't do the confirmation window that most fixes do and then doesn't take any time before it says it's done...and that seems odd. Same with Defrag All and Optimize Boot. None pop up the confirmation window and finish immediately. Defrag & Optimize works as expected.
Xander, if Defrag & Optimize is selected, Defragment C:, Defragment all drives and Optimize boot and shutdown are skipped, because Defrag & Optimize already does everything the other fixes do, and you wouldn't wand to defrag twice, would you? The same way, if Defragment all drives is selected, Defragment C: is skipped.
ghandi
Post by ghandi »
@Fred
Just ran it and this is debug.txt contents. Couldn't PM you; noob forum member:
Debug break point 1
Debug break point 2
Debug break point 3
Debug break point 4
Debug break point 5
Debug break point 6
Debug break point 7
Thanks ghandi, You've been a great help. It seem the bug was while getting the Windows product key from the BIOS.
Now, please download UVK.dll from the following location:
http://www.carifred.com/uvk/UVK.dll
Then move the downloaded file to UVK's install folder, overwriting the existing UVK.dll and run UVK to test if the issue is gone.
ghandi
Post by ghandi »
Fred wrote:Thanks ghandi, You've been a great help. It seem the bug was while getting the Windows product key from the BIOS.
@ Fred
Tried this and it works :-)
Thank you.
Now put out 7.8.0.2 and see if it breaks it for the rest of us :)
Hey Jim, have you got eyes on my brain or what? :shock: :shock:
ghandi, just out of curiosity, can you tell the make and model of your PC? Thanks.
texomans
Post by texomans »
This is all I get from the debug.txt file.
Debug break point 1
Debug break point 2
Debug break point 3
Debug break point 4
Debug break point 5
Debug break point 6
Debug break point 7
texomans thanks for your reply. I released a beta version yesterday in which I addressed this issue. You can find it here:
www.carifred.com/uvk/beta/
ghandi
Post by ghandi »
Fred wrote:ghandi, just out of curiosity, can you tell the make and model of your PC? Thanks.
It's a self build, intial build 2010 with a few upgrades (drives and graphics):
Main components are:
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
Kingston HyperX 6GB (3x2GB) DDR3 12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX)
Corsair Hydro H70 High Performance CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3)
Arctic Power Pro 850W Modular 14cm Fan PSU - 4x PCI-E 8x SATA
MSI AMD RADEON HD 7790 OC 2GB GDDR5
Creative SB x-fi
Sandisk extreme pro ssd (win 7 pro installed)
Intel 330 ssd
WD HDD wd10ezrx
Toshiba HDD hdwd120
Pioneer BDR208
