[Fixed] SAS
[Fixed] SAS
I have noticed that after allowing UVK to install SAS, the only way to uninstall it is to force uninstall. Are you aware of this Fred or did I find a bug?
Re: SAS
No bug, at least not a UVK bug. That's been discussed here already. I behaves the same if you install it manually or through TTS, but it doesn't do it in all PCs. I think it's a SAS bug.
Re: SAS
OKie. I've only actually used it on 3 computers recently as I don't use it very often but all three of them had to be force removed.
If it's not a UVK bug then not much you can do :)
