[Fixed] Use unattended mode check box check invisible
v 7.8.0.0 When in the repair section, when the unattended mode box is checked, it works but is an invisible check in the box. My apologies, I noticed this yesterday on a different computer and forgot to let you know.
Edit: It works unattended regardless of what I do.
Re: Use unattended mode check box check invisible
I see 7.8.0.1 in the future
It's behaving fine for me. Which windows version did that machine have?
It seems I should leave beta versions longer...
It happened on a Windows 10 x64 yesterday and today on a Windows 7 x86. Is it possible my. uvksr file is hinky?
I just tried it on a Windows 7 x64 computer with 7.7.2.3 and it works fine. It must have started in 7.7.2.4. Then I updated to 7.8.0.0 and the check is invisible.
Bill, I'm not being able to reproduce this issue. Perhaps if you send me your uvksr file I can figure it out?
It must be something that went crazy with my .uvksr file. I removed it and launched UVK and added a third party app and it works fine. I did pm you my .uvksr file so if you would take a look that would be super. Don’t waste too much time on it though. I can always rebuild it. Thanks Fred.
Maybe it’s not working so well. If I manually change use unattended mode in my .uvkrs file to 1 from 0 the box is checked when loaded, but if I uncheck it and save settings, I’m unable to recheck it when the settings load again. This also holds true for the new .uvkrs file I created that only has the one application I added. Not sure this information will do you any good but that’s what I found messing around a bit.
Ok, Bill, I figured it out. It should be now fixed in 7.8.0.1 (Jim was right )
Thank you Fred!
Jim, you can deflate your head now.
Should be "7.8.0.1"Fred wrote:Ok, Bill, I figured it out. It should be now fixed in 2.8.0.1 (Jim was right )
Change log:
Corrected typo 2.8.0.1. Now reads 7.8.0.1.
