SU - temporarily ignore whitelist
Most of the time, I want to hide occurrences of certain common softwares but, other times, I'd like to be able to see the whole list so that I can uninstall a normally-hidden program with the blacklisted ones or, say, mass-uninstall everything by a certain author.
Could the Menu button be given a 'Disable whitelist' option to show all files?
Re: SU - temporarily ignore whitelist
That makes perfect sense, Xander. I'll add a context menu item named Ignore Whitelist once.
