It's been a while since I've been here. I'm learning the program as well as some others. I have a question about sending reports though.
When I was creating a script I saw a message that said the email and FTP information could be exported to a Settings.ini file. Can someone walk me through that? Also is there a way to make the script check for the email information and if it's not already there the script can put it there?
Email reports
Re: Email reports
All settings can be exported to an INI file which is automatically loaded by UVKPortable and UVKSetup. Thatcan be done from the Options section, by clicking Export to file and saving in the same directory as your UVK package resides.
If you still want to ensure the email settings are OK before sending the reports from a script, proceed as follows:
- Launch UVK, go to the Reporting section, setup your email settings and click Save settings.
- Launch regedit, browse to the HKEY_LOCAL_MACHINE\SOFTWARE\UVK - Ultra virus killer key.
- Right-click the Reporting subkey and select Export. Export to reporting.reg, in the desktop.
- Right-click the new reporting regfile, and select Edit. Copy all the text in the file, except the first line that tells the version of the registry editor.
- In your script, just before the <SendReports> line, enter a line containing the <Reg> keyword, and then paste the copied REG code in the lines below.
<Reg>
[HKEY_LOCAL_MACHINE\SOFTWARE\UVK - Ultra virus killer\Reporting]
"SendEmail"=dword:00000001
"Subject"="New UVK - Ultra Virus Killer Report"
"SendFTP"=dword:00000000
"FTPType"="FTP"
"FTPPassive"=dword:00000000
"EmailAddress"="0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF"
"FTPServer"=""
"FTPLocation"=""
"FTPUser"=""
"FTPPass"=""
<SendReports>
