Autologin during SR run
Would it be possible for UVK to recognize that the current profile has a password on it and, at the start of its run prompt for that before it continues? And then, upon uninstalling itself, remove it?
I know that we can use the User Manager to affect that but, if it could be implemented as a specifically temporary measure, that would facilitate more automation when doing mid-SR reboots.
Alternatively, it could be set to check that upon UVK startup and undo, if changed, upon uninstall.
Re: Autologin during SR run
Hey Xander.
I'll see what I can come up with.
