SR's "Full disk cleanup" - use defaults when in unattended mode
Can the "Run full disk cleanup", when run as part of a full sequence unattended mode, be set to accept the default selections? But, if run by itself or not in unattended mode, offer the advanced options?
Re: SR's "Full disk cleanup" - use defaults when in unattended mode
I'll see what I can do, Xander. Probably add a new fix "Run normal disk cleanup".
