Auto check Port items
If this has already been done then point me in the right direction. Having the reporting auto check all the things in the list automatically so all I generally have to do is click Send reports.
Re: Auto check Port items
All items in the list are sent. The list contains the items already in the zip file, and it's the zip file that is sent. The check boxes are only to help you to select and remove several items at once from the zip.
