Un/reinstallinng Win10 apps
http://www.thewindowsclub.com/10appsmanager-windows-10
Portable app. Throw it on your flash drive, TTS, or wherever and use as needed.
Reinstalling provides you with the Powershell text to copy/paste into the editor.
Re: Un/reinstallinng Win10 apps
I will check this out, thanks :)
Thanks Xander. Just be careful not to uninstall the Windows store or Photos, or you'll not be able to re-install them again.
