TSPlus
FredJClaus
TSPlus
Post by FredJClaus »
has anyone ever used TSPlus? Anyone know about this sort of thing?
Re: TSPlus
I haven't. But there's a reddit topic here:
http://www.reddit.com/r/sysadmin/commen ... se_tsplus/
Re: TSPlus
Fred J
May I ask why you are looking in to it?
FredJClaus
Re: TSPlus
Personally, I'm not looking into it. My church has a computer that we run the database for our Church Management software on. TSPlus is a program one of the network guys suggested as a way for our finance team to be able to sit at home and remote into the computer at all hours when they need information.
Trouble is, I can't seem to get it to work properly and the only tech support is a support ticket that we have to wait for someone to reply back on. I can't sit at the church all day waiting.
Re: TSPlus
If there are not any special requirements, there are tons of ways you can do that. RDP would the most readily available one.
FredJClaus
Re: TSPlus
There are special requirements because what they are doing is running the program on their computer, but connecting to a database on the server in the office. I talked with TSPlus and it is not an issue on their end. We set up an account with NoIP.com to host a DDNS server and that is what's messed up.
FredJClaus
Re: TSPlus
Kind of like when I screwed up my AWS account remember Jim?
Re: TSPlus
OK what database server are you using? Did you port forward on the church router? I can think at least a couple easy solutions right off the bat for server client fixes depending on your database type
FredJClaus
Re: TSPlus
Well, it's a church program that we are using for the database. I have TSPlus as the program that will remote into the computer via a server through NoIP.com Figured out it is not the programs that are messing up though, it's the computer. I put the file on another computer and it remoted in just fine. Turns out the computer is looking for the computer at the old location, and I can't seem to clear it out.
question, though. Why are they using TSPlus when the computer is a Windows 7 Professional and it had Remote Desktop Connection access?
FredJClaus
Re: TSPlus
Fixed the issue. Why is it we never look at the simple solutions first? I changed the name of the file and it works fine now.
