Power Settings - be able set our own defaults
On laptops, I set the Power button and Lid-Close settings to Hibernate. I had two client laptops in the last year where they closed the lid, it went to Sleep and then they stuffed it into a bag causing the CPU to overheat. After that, I started making that my default setting.
I'd like a way to be able to set the power settings, either in a script or within the System Repair section to our preferences.
Re: Power Settings - be able set our own defaults
Hi Xander,
From the welcome screen check the “IT/Geek tools” section. Then under “Enable/Disable (select)”. There is a setting there. See if that will work for you. :)
Xander,
I don't think we could ever find a default schema that would please everyone, so I guess setting up a System repair fix for that effect would not be possible.
However, I can build a script based on this one for the effect. I'll give it a shot tomorrow.
Code's a little beyond me but I'm open. It's currently something that I have in the SR as just "powercfg.cpl" which opens automatically to remind me to set it. Being able to set it automatically would be obviously better.
What about something a little like the <ImunizeSettings> (misspelled, btw) where there's a scripting command "<___>" with parameters?
___________
The Immunization part got me thinking: is there a way to enter a <scriptcommand> in the SR section? So that one could enter, say, <ImunizeSystem>0|2|15|20 as the command line and have it perform that action?
I know a lot of of script functions are duplicated in SR but not all so wondering if there's a built-in way to use them in the SR stuff.
How about just add a setting and let people pick the action they want for power settings? The tech settings, as far as I'm concerned are fine. But, not everyone wants the default windows power settings to be restored which is essentially what UVK is doing now.
Sorry, I misread that first post. I normally set them to never sleep or hibernate but to shut down. I don’t care for those options. On or off, that way it’s accessible or it isn’t.
Charger440 wrote:How about just add a setting and let people pick the action they want for power settings? The tech settings, as far as I'm concerned are fine.
The settings during our work are fine. I'm asking for the ability to set them to my liking automatically.
Charger440 wrote:But, not everyone wants the default windows power settings to be restored which is essentially what UVK is doing now.
Right and, if I read Fred's reply correctly, he's looking in to the ability to set them to our preferences.
Win win.
Win win.
What I got out of Fred's post was that he would make a script that instead of asking "Yes" or "No" would allow us to select the option for the item. What I thought would be a better solution is to leave the power settings like they are but ADD the default action to the user options and just have the current power settings menu item use the default action we setup. Essentially what you said but, I wanted to be more clear in what I was talking about.
If I make a script or add a feature that allows us to set the power options we want, it will not be any different from the custom app Xander made that runs powercfg.cpl. I was going to make a script that sets close lid actions to Hibernate, in all power schemes, and for both "On battery" and "Plugged-in" states.
Xander, here's the script I promised. It will set the "Close lid" action to "Hibernate" for all power schemes, and for both "On battery" and "Plugged-in" states.
 <AutoItScript>
;#RequireAdmin
Global Const $tagGUID = 'ULONG Data1;USHORT Data2;USHORT Data3;BYTE Data4[8]'
Global Const $GUID_SYSTEM_BUTTON_SUBGROUP = '4f971e89-eebd-4455-a8de-9e59040e7347'
Global Const $GUID_LIDCLOSE_ACTION = '5ca83367-6e45-459f-a27b-476b1d01c936'
Global Const $GUID_MAX_POWER_SAVINGS = 'A1841308-3541-4FAB-BC81-F71556F20B4A'
Global Const $GUID_MIN_POWER_SAVINGS = '8C5E7FDA-E8BF-4A96-9A85-A6E23A8C635C'
Global Const $GUID_TYPICAL_POWER_SAVINGS = '381b4222-f694-41f0-9685-ff5bb260df2e'
Global Const $LID_CLOSE_INDEX_DONOTHING	= 0
Global Const $LID_CLOSE_INDEX_SLEEP		= 1
Global Const $LID_CLOSE_INDEX_HIBERNATE	= 2
Global Const $LID_CLOSE_INDEX_SHUTDOWN	= 3
_SetLidCloseToHibernate()
Func _SetLidCloseToHibernate()
	Local $ret = 0, $PowerID  = _PowerGetActiveScheme()
   ;Lid Close
   Local Const $GroupId = _UuidFromString($GUID_SYSTEM_BUTTON_SUBGROUP)
   Local Const $SubGroupId = _UuidFromString($GUID_LIDCLOSE_ACTION)
   Local Const $value = $LID_CLOSE_INDEX_HIBERNATE
   $ret += _PowerWriteACValueIndex($PowerID, $GroupId, $SubGroupId, $value)
   $ret += _PowerWriteDCValueIndex($PowerID, $GroupId, $SubGroupId, $value)
   $ret += _PowerWriteACValueIndex( _
   _UuidFromString($GUID_MAX_POWER_SAVINGS), $GroupId, $SubGroupId, $value)
   $ret += _PowerWriteDCValueIndex( _
   _UuidFromString($GUID_MIN_POWER_SAVINGS), $GroupId, $SubGroupId, $value)
   _UuidFromString($GUID_TYPICAL_POWER_SAVINGS), $GroupId, $SubGroupId, $value)
   ;Apply changes
   Local $msg = _PowerSetActiveScheme($PowerID) And $ret ? _
   'The Close lid action was successfully set to "Hibernate".' : _
   'The Close lid action could not be set to "Hibernate".'
   ;Free the pointer
   _LocalFree($PowerID )
   MsgBox(0,'Technician Settings',$msg&@CRLF&@CRLF&$ret&' power policies applied.')
EndFunc ;==> _SetLidCloseToHibernate
Func _PowerGetActiveScheme()
   Local $aCall = DllCall('PowrProf.dll', 'DWORD','PowerGetActiveScheme', 'ptr',0, 'ptr*',0)
   If @error Or $aCall[0] Then Return SetError(1,0,0)
   Return $aCall[2]
EndFunc ;==> _PowerGetActiveScheme
Func _LocalFree($hmem)
   Local $aCall = DllCall('Kernel32.dll', 'ptr','LocalFree', 'ptr',$hmem)
   If Not @error Then Return Number($aCall[0] = 0)
EndFunc ;==> _LocalFree
Func _PowerWriteACValueIndex($SchemeGuid, $SubGroupGuid, $SettingGuid, $AcValueIndex)
   Local $pSchemeGuid = IsDllStruct($SchemeGuid) ? DllStructGetPtr($SchemeGuid) : $SchemeGuid
   Local $pSubGroupGuid = IsDllStruct($SubGroupGuid) ? DllStructGetPtr($SubGroupGuid) : $SubGroupGuid
   Local $pSettingGuid = IsDllStruct($SettingGuid) ? DllStructGetPtr($SettingGuid) : $SettingGuid
   Local $aCall = DllCall('PowrProf.dll', 'DWORD','PowerWriteACValueIndex', _
   'ptr',0, 'ptr',$pSchemeGuid, 'ptr',$pSubGroupGuid , 'ptr',$pSettingGuid, 'DWORD',$AcValueIndex)
EndFunc ;==> _PowerWriteACValueIndex
Func _PowerWriteDCValueIndex($SchemeGuid, $SubGroupGuid, $SettingGuid, $AcValueIndex)
   Local $aCall = DllCall('PowrProf.dll', 'DWORD','PowerWriteDCValueIndex', _
Func _PowerSetActiveScheme($SchemeGuid)
   Local $aCall = DllCall('PowrProf.dll', 'DWORD', 'PowerSetActiveScheme', 'ptr',0, 'ptr',$pSchemeGuid)
EndFunc ;==> _PowerSetActiveScheme
Func _UuidFromString($guidStr)
   Local $sret = DllStructCreate($tagGUID)
   Local $aCall = DllCall('Rpcrt4.dll', 'DWORD','UuidFromStringW', 'wstr',$guidStr, 'struct*',$sret)
   If @error Or $aCall[0] Then Return SetError(1,0,$sret)
   Return $sret
EndFunc ;==> _UuidFromString
CloseLidAction.uvk
(4.54 KiB) Downloaded 182 times
Enjoy!
