Recovery
FredJClaus
Recovery
Post by FredJClaus »
This was a thought after I used the Backup feature of UVK, and screwed everything up.
Data Recovery feature: Some people call it "Undelete". If you accidentally delete files you need, It would be cool if I could use my UVK scan the computer and recover deleted files.
Is this doable?
Re: Recovery
I'm not sure about UVK but there are several tools out there (some free) that can do this already. A couple of them are pretty cheap and might be a low cost investment for someone in the repair business...
Re: Recovery
I'm using the Tech Tool Store for those "sometimes" tools. With the current configuration options, I've settled for using the SR section for programs that are necessarily part of the workflow and using the Tech Store for the infrequent programs.
