WaitWindow
WaitWindow
<Run>
cmd
->WaitWindow(100000, C:\Windows\system32\cmd.exe)
->WinSend(diskpart {enter})
 <Sleep>10
->WinSend(automount enable {enter})
This is the closest I have ever gotten WaitWindow to work. This script works fine up until the second WinSend and it will not send it. I'm not sure why and the script windows usually does not report any errors so I can't really go on anything there.
Re: WaitWindow
Hi Jim.
The automation functions must be used inside the <Run> mode. At the line <Sleep>10, the mode is changed to <Sleep>, so ->WinSend(automount enable {enter}) does not work. Also, there is a bug and the Run scripts section is not logging anything, that's why you don't see any errors. It's already fixed, I will upload a new beta today.
This works for me:
<Run>
%Comspec% /c diskpart
->WaitWindow()
->Sleep(4000)
->Sleep(4000)
->WinSend(exit {enter})
